I'm looking for a drawing of the Transit Drag link. I've search the forum for houts and have only come up with a Transit TRE drawing. I
know the TRE is M20 vs M18, but I'm unsure what else is different.
Failing that, could someone with a Transit Drag link measure ball joint center to the end of the M18 shank?
Any other measurements would be a bonus.
Thanks,
Mark
I think I might have something - here's a photo but I don't suppose that's any use
I took a ruler to the picture and came up with some real small measurements.
Thanks Raz, I appreciate you looking.
Mark
If you need anything better, I have a dxf file of a drag link. Can't remember where it came from so I can't vouch for it's accuracy but it looked about right!
Please...
You can send it to mconley3@yahoo.com
Thanks!
Mark
I just checked on Locost CAD resource and the cupboard was bare. If you
do have a diagram it would be a good addition to the library
James
emailed it across to you - sent both a DWG and a DXF. As I say I can't vouch for accuracy as I haven't got a link to compare it to, but
I'm pretty sure it came from a reliable source!
Puk - how do I add it, or am I being thick?
If Mark can provide (well, confirm!) a couple of dims on it for me to validate I might even knock up a full 3D job when I have a mo.
Thanks! I'll try to take a look tonight, I may not have time till tomorrow though.
I don't have one to compare/verify the drawing. I'll try to export to a pdf, or something else and post it. Maybe Raz could verify the
measurements.
Mark
[Edited on 4/23/2008 by mconley3]
Originally posted by mconley3
Maybe Raz could verify the measurements.
Sent email...
I have a friend adding measurements and converting to pdf. I'll post if he ever gets back to me.
Mark
I got the following back from the email.
You do not have permission to post to group locost-cad-models. You may need
to join the group before being allowed to post, or this group may not be open
to posting.
Visit http://groups.google.com/group/locost-cad-models/about?hl=en to join or learn more
about who is allowed to post to the group.
Help on using Google Groups is also available at:
http://groups.google.com/support?hl=en
Here is the first attempt. I've asked to get a side view also. The sleave and nuts on the shank don't seem to be seperate, so I'm
unsure of the length of the shank.
Could the length from the balljoint to the end of the shank really be 5.301"?? That seems very long.
Mark
Hi,
Does anyone out there know whether it a Left Hand (Nearside) or Right Hand (Offside) drag link that is needed?
Help! I know it's M18 right hand thread, but which side of the transit??
http://www.super7thheaven.co.ukhttp://www.super7thheaven.co.uk
emailed it across to you - sent both a DWG and a DXF. As I say I can't vouch for accuracy as I haven't got a link to compare it to, but I'm pretty sure it came from a reliable source!
