Is anyone using the GTS type shocks? I am trying to order new springs with different rates but I am unsure of the internal diameter to use. I measured
the thread of the coilover and is 44.5mm. If I use internal diameter springs of 1.9in (48.5mm) would it be ok on my type of shock?
Here is a photo of my coilover:
Gts Shock 2
Yes they are 1.9 inch dampers.
Paul.
You will need to know the unfitted length as well, of course.
If that is a coilover off your car it looks like the suspension travel is quite limited. Are you thinking of going for a longer, softer spring?
[Edited on 17/5/08 by mr henderson]
Thanks Paul, and one other thing please. I jacked the car up to have a look at the shock length when unloaded. The length between the (not sure how to
describe it so attached a photo) is 8.5 inches. So does that mean I should be using 8 inch free length springs all around or should the lengths be
different in the front and rear?
Coilover-edit
Just came back from the garage Mr Henderson, so I missed your post. In fact I wanted to ask about what spring length to use... I also saw your post
in my other thread, I have tried riding in a Dax Rush, which seems to
be softer but then again 200kg heavier than me.
I took a 110Kg passenger once with me and the ride improved by ALOT, so thats why I was hoping to get a better result with using softer springs.
Ok, I can do all that. However if I reduce the unsprung weight it, will improve the ride quality as well or just the handling?
Yeah, thats where anti-roll bars come in....
Thanks for the info, I'll keep a few sets of springs and experiment. It is a Lowcost after all.
