GTS Shock Kit Vs. Mk's Protech Alloy dampers
Staple balls - 28/11/03 at 08:53 AM
as title really.
should i go for the GTS shocks or the protechs on an indy?
unless anyone else knows of something better for under £300 that is
ned - 28/11/03 at 09:43 AM
There have been various threads disuccing the pros/cons of adjustable vs fixed rate dampers. These alloy bodied dampers are nice and light, my preference would be the protech adjustables though.
Other shocks for under£300 are the dampertech ones, gaz i believe. Though it is common knowledge that spax/avo/gaz are basically the same units.
I picked up some spax shocks for £100 second hand.
Ned.
[Edited on 28/11/03 by ned]
Mix - 28/11/03 at 09:44 AM
Could we also include Dampertech's Gaz dampers in this discussion. (Currently on offer)
Mick
Staple balls - 28/11/03 at 09:47 AM
Mick
go for it. got a link?
ned - 28/11/03 at 10:07 AM
Sorry,
thought i'd already mentioned them.
Ned.
Mix - 28/11/03 at 10:21 AM
Staple Balls
Gaz currently advertised in kit car mags for £250 a set of four inc VAT & P&P
Tel 01709 703992
Ned
You did, Beat me by a minute, must learn to type with more than two fingers
Mick
Staple balls - 28/11/03 at 10:34 AM
this is all very well and good.
but which are best? i'm tempted to lean towards the GTS's, they look pretty
Staple balls - 28/11/03 at 12:39 PM
it'll have to be ajustable, mainly because i'm a lardarse and i like the fiddle with stuff
ned - 28/11/03 at 12:51 PM
sounds like the protec if you want alloy adjustables or gaz if you don't mind steel ones.
Ned.
Tigers - 28/11/03 at 01:01 PM
Do you have a link where I can see those protech coilovers? Are the the same dimensions?
Staple balls - 28/11/03 at 01:03 PM
http://www.m-keenan.freeserve.co.uk/price.htm
ned - 28/11/03 at 01:05 PM
i've seen them in the flesh at the donington show, look nicely made and are quite light. I'll probably get some alloy ones eventually once the car ison the road/track!
Ned.
dozracing - 28/11/03 at 02:00 PM
Hi all,
I haven't read all the threads cos i don't want to get into another slagging match.
I'm out of stock of MK Indy shocks, and, as business is booming in other areas i'm not convinced i shall bother with MK shocks in the future. I had some involvement with the Protecs, and as such would rather people buy them than the Gaz and Avo equivalents. The Protecs internals are a step forward in terms of design than either the Gaz or Avos.
Kind regards,
Darren
ned - 28/11/03 at 03:47 PM
Darren,
I am happy that things are going well for you, and equally pleased that you are suggesting other manufacturers products as a good choice. Some manufacturers might try to sell their products regardless. I think this can only be good for your business and the lcost community.
Ned.
pbura - 28/11/03 at 07:18 PM
This hasn't been discussed much, but the GTS shocks are monotube, making for more efficient and consistent damping than a twintube type.
Are the Protechs monotube as well?
