Difference between Granny and Sierra callipers
James - 1/12/03 at 03:15 PM
Hi,
I've noticed a slight difference between the Sierra and Granada rear callipers I have.
The Granada have a small (2/3mm internal diameter) threaded hole next to/beneath the handbrake spring.
Anyone know what this is for or if it's at all relevent to anything?
Thanks,
James
bob - 1/12/03 at 03:23 PM
They are the same part number for regular pads and the carriers are same,doubt its going make any difference.
Those calli's you had from newlands are the ones i put against my sierra ones,couldnt see any differenceon mine.
ChrisW - 1/12/03 at 03:41 PM
I've got a pair of each too and couldn't see any difference. Just picked the best two so I may even have Granny one side Sierra the other. Perhaps it's just differences in the design between years?
Chris
stephen_gusterson - 1/12/03 at 03:49 PM
its not where they poke a wire in for the brake wear indicator is it?
atb
steve
blueshift - 1/12/03 at 04:33 PM
Our sierra 4x4 calipers have the same threaded hole (sort of opposite the handbrake return spring stop bolt hole). Nothing was screwed into it.
James - 3/12/03 at 04:20 PM
Ah, but the question is:
what super-duper gadget were Ford intending to screw into it!
James
ned - 3/12/03 at 04:33 PM
i'm guessing some sort of brake wear, fliud pressure or handbrake sensor.
Ned.
stephen_gusterson - 3/12/03 at 07:08 PM
perhaps it was for a secret microphone or tracking device
or a place to store this years pay rise
atb
steve
