bump stop!!??
chris_smith - 16/6/08 at 12:36 PM
tried to do a search not found anything.
does anyone have any pics as to what they used for rear axle for bump stops if anything at all.
thanks in advance
chris
Mr Whippy - 16/6/08 at 12:45 PM
the rear ones off classic vw beetles are very cheap and easy to fit over a large bolt head
at the very bottom of the list >
http://www.vwheritage.com/ssp/Rear-Suspension/?templateID=ssp
about 3 inchs in length if that helps
just don't let the wife see them as she might think they are something else altogether and give you a slap though you could be lucky...
[Edited on 16/6/08 by Mr Whippy]
twybrow - 16/6/08 at 07:10 PM
I've just glued some 6mm thick rubber onto the chassis rail. It looks like it will take quite some force to get anywhere near it - but we'll see!
neilj37 - 17/6/08 at 12:02 PM
You could always use the same ones they use on a TR6
http://www.rimmerbros.co.uk/rimmer/triumph/tr6/susp-rear
Item 30 - They are rubber with a bolt type insert moulded into it
