I am trying to find the following drive flange from a sierra. Can anyone tell me which model the following picture is off:
https://www.caterhamparts.co.uk/popup_image.php?pID=543
I would buy it brand new at a last resort however I want to stick to a small budget.
James
Whats wrong with the ones you've got?
It looks 'similar' to the sierra ones - but whats the PDC on your wheel studs? (fords are 108mm)
I's guess they are more likely to be the same as the drum braked type
(but I've never had a set of drum braked ones to compair them - is there any difference? they look the same as the disc type ones :? )
drum braked type:
[Edited on 24/9/08 by mcerd1]
I don't have any at the moment. I bought a Caterham 1996 S3, which was pretty much in rolling chassis form without the rear brakes, drive
flanges, hub and calipers.
I need to buy the rear suspension braking setup (listed above).
I wanted to keep cost to a minimum as I am already racking up expenses due to ordering parts from caterham!
I though as most parts are from a sierra that I could source and clean them up myself. Have the same drive flanges been used throughout the series
history of the sierra?
James
i have some bits n bobs for sale if there any good to you
wayno
