I am avoiding vast outlays, I know you can make your own (not enough expertise/equipment), buy an aluminium one (too much) or use a Mini estate/van tank (rocking horse shite). Any other standard car tanks that will fit the Ron C Locost?
i got this one
http://www2.obp.uk.net/catalog/product_info.php?products_id=162&osCsid=5d5c557ebe5ba05c17ef91368d60a47a
same size as the ali ones but mild steel powdercoated seems ok think hes on here too the owner of the shop there is a smaller one thats cheaper too
[Edited on 22/10/08 by adam1985]
i know someone who used one from a robin
contact deneo on here!
I looked at the Triumph Spitfire tank - mild steel but fitted inside the boot hence usually rot free.
It looks the right shape but check the dimensions it was a bit too long for my Stuart Taylor/Aries Motorsport chassis.
