Hi guys,
Just started fitting my brake pipes today and wondered if i need to fit a brake bias valve to my Indy? If so do you know where i can pick one up?
Dave
I have one fitted but the lad's at MK say you don't need one at least that's what they said 4 years ago
mk and mac#1 tell u that the sierra master cylinder bias is perfect ballance for the indy
cheers guys
Ive found driving various Indys on track,in wet or damp conditions,they all tend to lock up the rear brakes during very heavy braking,so fitting a
brake bias valve to be able to reduce rear axle braking in these conditions,such as a wilwood,in my opnion is a good idea.
