Just making some space in my garage, these items are now surplus to requirements. If you need any more details drop me a PM or text/call me on 07866
465125.
Thanks.
1 x Radical Prosport Carbon Airbox c/w K&N filter and original latch clips. One edge needs a little tlc to seal the hairline crack, a common issue
with these air boxes. This airbox and filter are around 400 quid new and are very effective. Bargain at £100
1 x set Hayabusa Throttle bodies removed from an early Radical Prosport, been stored for a while and surplus to requirements. £95
1 x set of AVO alloy Single Adjustable dampers for a Radical Prosport / SR4, stripped and re-valved for a racecar. I pair requires a set of springs
and the alloy top retaining cap, now surplus to requirements.
Open lengths Between Centres - 1 pair 310mm with 7" spring x 330lb / 2nd pair 330mm with 350lb x 8.5"
SOLD SOLD SOLD
Images are in my gallery but i can easily e-mail high resolution pixel quality photos to you if needed
Thanks,
Myd
[Edited on 31/10/11 by MydT9]
U2U re: coilovers
All U2U's replied
