wtd 2.0 pinto
JAMSTER - 3/1/10 at 05:26 PM
wanted 2.0 pinto cheeeeeeeep as pos please for kit car build thanks
[Edited on 3/1/10 by JAMSTER]
DRC INDY 7 - 3/1/10 at 05:32 PM
I know it does not help but i have a 1637cc pinto engine for sale
3000 miles from a total rebuild with rebore and new pistons £200
JAMSTER - 3/1/10 at 05:38 PM
whats the full spec does it have kent/piper cam carbs exhaust
i have a 1.6 but straight out of doner and i have some what i think are zx6 carbs
i also have a 1.8 duratec just a little complicated stick to simple for now
*davies144* - 3/1/10 at 05:45 PM
hi i also have a fully re-conned 1600 pinto with polish ports? its in two halves ready to go back together £100? ono
DRC INDY 7 - 3/1/10 at 05:47 PM
New camshaft kit standard
all valves lapped in
AE cast plus 1mm pistons
polished crank with all new bearings
high pressure oil pump
engine has done 3000 miles since the rebuild comes with no ancillaries no clutch
i ran this on zx6r carbs
requires sump and cam cover
[Edited on 1/3/2010 by DRC INDY 7]
philhoward - 3/1/10 at 06:34 PM
I have a 2 ltr Pinto available that you can have for £30.00. (not a 205 block). It has not been run for years so could be siezed, so would probably need a rebuild. The crank pulley and oil seal housing are missing but these could be easily replaced. Let me know if you are interested.
ash_hammond - 3/1/10 at 09:04 PM
Phil, second dibs if JAMSTER is not interested.
-- Ash
ash.hammond(at)gmail.com - my u2u does not work.
FASTdan - 7/1/10 at 09:24 PM
We will be selling our 2.0 pinto:
Out of a 100k injection sierra. Valves reground, Honed, new HG approx 2000 miles ago.
Running twin dellorto's made 110bhp@rear wheels on bogg bros rollers.
Everything available apart from exhaust manifold and it can be seen running (passenger ride) in the car.
U2U if of any interest. Located Bradford, West Yorks.
jacko - 8/1/10 at 07:29 PM
This any good to you
http://www.locostbuilders.co.uk/viewthread.php?tid=127919
