wanted: 5mm brass olives (MTB disc brakes)
02GF74 - 9/9/10 at 02:45 PM
apparently you can buy these in bulk - 5 mm brass olives that fit on brake hoses used on mountain bikes.
cheapest I have found are these not sure if they are suitable though.
do you know of any other sources?
(shimano ones are £ 1.50 each )
[Edited on 9/9/10 by 02GF74]
blakep82 - 9/9/10 at 02:47 PM
plumbers merchants?
grub - 9/9/10 at 02:49 PM
it says there for nylon hose not braided i would get some from merlin cycles least they will be the right ones
02GF74 - 9/9/10 at 02:55 PM
searched on line (brass olive, brass gland) doesn't come up with much from plumbers merchants - maybe I'll go to a couple in person.
the hoses I use (shimano and magura) are nylon outer, braided ones are goodridge and use a different fitting system not involving brass olives.
Peteff - 9/9/10 at 04:43 PM
Try a pneumatic/hydraulic supplier, they have them to fit small compression fittings for nylon pipe.
Like this place.
[Edited on 9/9/10 by Peteff]
Marcus - 9/9/10 at 05:47 PM
What about these?
Linky
Davey D - 9/9/10 at 07:32 PM
There are some here:
http://www.chainreactioncycles.com/SearchResults.aspx?Search=olive
What brakes do you have? Ive got Avid Elixr R, and recently shortened my hose as it was too long. i used an Avid Barb, and Avid olive, and it worked spot on
02GF74 - 10/9/10 at 06:11 AM
^^^ brill, thx for searching, I knew locostbuilders would come up trumps.
12p per olive - brillo!!! better than £ 1.50 from Chain Reaction and other bike places.
I have Shimano XT and Magura Marta, both use same size hose - 5 mm so work with 5 mm olives.
The little barbs are compatible too, they're to stop the tube crushing, well, they would be since I am using Shimano hose for both (Magura is much more expensive).
[Edited on 10/9/10 by 02GF74]
