hi Im after a lightweight flywheel for my 2.0 silvertop zetec for a fwd car, or advise on where sells them cheap, thanks in advance
RWD Motorsport
Or get the weight round the outer edge of the rear taken off
Machine shop can do this
Have you thought of fitting a 1600 flywheel as they are lighter.
1.6 Efi FIesta flywheel is lighter but you have to enlarge the bolt holes 1mm before it will fit onto a 2.0 silvertop.
I have a 1600 zetec flywheel that has been machined so you can fit a pinto clutch, looking for £45.00 if you want it.
I've been using a 1600CVH flywheel and clutch for 7 years with no problems. Revs up fast.
Bill
