anytone used this site to bye there tyres?
Did you forget the link Tom ?
sorry yes, forgot the link! must be tired (or old!)
[img]http://www.tyretraders.com/[/img]
I work right by tyretraders and we order off them about 5 times a day.
Never had any problems and the prices are ok. Let me know if they sting you on delivery as i can collect them for you
Shaun
TOYO 195/55R15.85V Proxes T1-R for £34.66 inc vat and £10 delivery for the 4
total £148.10 looks good to me! so I've ordered them!
While i rated them on my TVR's i have them on the thing on the left and i'm not that impressed, probably because it's half the weight of the TVR and doesn't work them that well, i will be going down the R888 route next.
T1-R 195/55 15s for 34squids each?! Is this correct ?! (I can't get the link to work you see) Thats 15-20 cheaper per tyre than anywhere else
I've seen. Need some of this size for the road car so I might be buy if the prices are correct!
Edit: link now works. Wow, they are cheap.
[Edited on 7/10/08 by andylancaster3000]
Tyre traders
that should work now
£35 a corner is not an uncommon price for these in this sort of size (anywhere between 45 and 55 profile in a 195 wide 15" diam) if you shop
around. Although you've got to allow for fitting if buying them supply only.
One of the reasons I went for 15's was cheap rubber although on reflection when you look at the stickier tyres there aren't really any
savings over 13".
[Edited on 7/10/08 by hobbsy]
also try
camskill
and mytyres.co.uk
they offer free delivery too, used both and there very competative
HTH
Mitch
Eeek!
was about to recommend mytyres ans went on to check their current prices...
I paid about £45 for my rears just over a year ago...
they are now £126!!!
that'll teach me to go for a tyre size that is only available from one manufacturer! (245/35/16)
I found this whilst browsing. Prices seem good.
195/50-15 TOYO PROXES T1R
£29.00 Postage: £6.00
ALSO
195/50-15 YOKOHAMO PARADA SPEC-2
£31.50 Postage: £6.00
http://stores.ebay.co.uk/tread1783_195-50-15-TYRES_W0QQcolZ4QQdirZ1QQfsubZ5QQftidZ2QQtZkm
I think philw right so the T1R,s are for the tin top , I've R888 on the indy!
