roll cage wing mirrors
stripe - 22/6/07 at 06:38 PM
hi there,
recently ive seen a few caterhams about with full cage's and wing mirrors that bolt on to the cage on what would be the A-pillar. I'm guessing they kinda just have a strap/jubilee clip round the tube... does anywhere know where i might be able to get some as there some of the last items i need....
ive had a quick look on caterham website/store and on the caterham section of demon theives.....
click for sample pic
cheers for any help
james
12a RX-7 - 23/6/07 at 12:00 AM
or weld some mountings to the cage, just don't drill the tube!!
procomp - 23/6/07 at 07:56 PM
Hi as you can see here. Most weld mountings usually a small flat plate.
Or some use as said jubalie clips.
Invertations to pass up the inside where sent out the previous week.
[/img]
Sorry big pic but only one with close enough detail.
cheers matt
[Edited on 23/6/07 by procomp]
Simon - 24/6/07 at 11:32 AM
James,
Could you not make up a clamping bracket.
Piece of tube that would slide over rollcage tube. Cut that lengthways, weld on flats for mirrors to bolt to, and to clamp with.
Take a couple of hours and cost a couple of quid.
Simon
stripe - 24/6/07 at 12:05 PM
cheers for the replys guys, i think i might try the jubilee clip way to start with as i dont really want to damage the powdercoating on the cage so i can weld them on...
when i have seen them before the cars are always going past too quick to have a proper look.
thanks
