I've a reasonably long (12 inches or so) braided fuel line forming the return from my fuel rail back to the swirl pot.
It's got a reasonably big curve in it (needs to turn through 180 degrees to go back from the front of the engine back towards the swirl pot) and
it's sprung a leak...
Suggestions on a) why this has happened
b) how to avoid it happening again
don't really want to plumb a copper / kunifer line right the way to the front of the engine, but will if I have to....
Just noticed - you can see it in the picture
<------Here
Poor quality hose, http://www.locostbuilders.co.uk/viewthread.php?tid=115347
Pretty sure it was either from Think Auto or Merlin...
Reading that thread, I think I might pull all the braided hose off and replace with something I can visually inspect....
Tintops don't have this problem...what's different?
OK..Question for the rest of the experts now...
Fluorosilicone Lined Fuel/Oil Hose
Is it suitable for use in a (high pressure) Fuel Delivery system? What standards should it have to meet?
[Edited on 15/9/10 by stevebubs]
If it's not injection rated hose get it off NOW.
Most of the braided stuff is only rated for a few psi unless stated, alright for carb pressures but several bar and all that's stopping it from
bursting is the braiding.
Don't forget the fuel tank, pump and swirl pot pipes.
Replace with injection hose from halfrauds, for IVA so they can see the markings on the hose then cover in overbraid after IVA
I use ordinary rubber fuel hose for two good reasons - it's cheap as chips , and can be replaced in minutes
I've got a big coil of it hanging in the garage if you need some ?
I use this stuff without an issue. Note the minimum bend radius.
http://cgi.ebay.co.uk/6-MSA-Rally-Teflon-Stainless-Braided-Fuel-Hose-6m-/150368124997?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2302a38045
You will need fittings for the teflon hose as well.
[Edited on 15/9/10 by jeffw]
Originally posted by clairetoo
I use ordinary rubber fuel hose for two good reasons - it's cheap as chips , and can be replaced in minutes![]()
THREE good reasons. The third being, that you can SEE when and where it has perished.
It's the proper stuff and sold as suitable for injection. The fuel system was an area I didn't scrimp on precisely for this reason.
Claire - thanks for the offer (again), but rubber injection hose is pretty cheap so I'll probably just pick a couple of metres up from a local
autofactors...unless someone can point out some "blingy" stuff that doesn't have braid and is hence inspectable....hence my question
about fluorolined silicon...
Originally posted by BenB
2.5bar of RON95 pissing all over a red hot engine probably would be classed as "not a good thing"![]()
This wasn't particularly cheap and was procured from what should be a reputable supplier...
I've experienced fuel hose that I bought from a local factor perishing, it's not that uncommon. There seems to be a lot of dubious stuff around. Anyway, best that I've bought for the high pressure injection circuit was from Car Builder Solutions. Been on for nearly 3 years now and with some tight curves, and not a sign of wear and tear. As said previously avoid braided, it only serves to hide any potential splits.
