Track day noise limit
ritchunt - 17/8/11 at 03:50 PM
A couple of questions im planning on doing a couple track days again in the next few months but im unsure of the db reading of my 205 im going to buy a db meter of ebay but do they use type a or b to test? And also i do not have a rev counter how will they determin my rpm to carry out the test? Will this be a issue?
will121 - 17/8/11 at 05:39 PM
Looking at my instructions I got from javelin for a track day on Monday its dBA range as for rev's think most noise testers know what 4500 rpm sounds like which is a general test level for a 4 cylinder 6500 red line, I would just say you will have to rev it to a level that they consider is acceptable, normal test is 0.5m from tail pipe at a 45 deg angle
johnemms - 17/8/11 at 06:01 PM
Can't you down load a widgit from the marketplace ?
For your phone 'db meter'
For all you iphone & android phone users
jon
eddie99 - 17/8/11 at 06:12 PM
Noise test will be at 3/4 max revs..... RPM will be needed, we had a broken RPM one trackday and used the multimeter to show a rough RPM
mark chandler - 17/8/11 at 06:19 PM
I have an Ebay db meter
[img]NEW SILVERLINE SOUND LEVEL METER 50-126DB 633937 | eBay[/img]
It measures exactly the same level as the scrutineers meter at Goodwood, in my case to loud
If I switch from A to B it seems to make little difference, the needle is just a little more stable but the actual value is pretty constant.
My car was knocking out 103db BTW
Regards Mark
ritchunt - 17/8/11 at 06:20 PM
Thanks i will try to sort something, ive never really needed one, i did think of downloading one but i would assume they would be pants how can your phones speaker possibly be accurate
LBMEFM - 17/8/11 at 07:16 PM
Item condition: New
Quantity: 8 available / 12 sold
£15.99 Buy it now
Four buyers are going to be disappointed
bmseven - 17/8/11 at 07:20 PM
Tested the Android Widget beside a good quality commercial DB Meter and the difference was almost non existent, I guess noise is noise.
DRC INDY 7 - 17/8/11 at 07:24 PM
Item condition: New
£15.99 Buy it now
There would have been 20 for sale in the first place hench 12 sold and 8 left
ritchunt - 17/8/11 at 09:12 PM
Just tried a widget it was reading my tv at nearly 80dbs from around 10ft? On a low volume, Never mind ive ordered a proper one of ebay should have it soom ill just test my car all the way up the rev range and see what its reading full bore, hope im not one of those 4 lol
