Antifreeze mix
jacko - 19/10/11 at 06:21 PM
Hi All
Now it's getting colder and the frost and snow is on its way I think it's time to check the strength of the antifreeze So what would you Gent' suggest the ratio should be ?
Jacko
Daddylonglegs - 19/10/11 at 06:27 PM
50:50
stevegough - 19/10/11 at 06:43 PM
If its anything like the last 2 years.......200% antifreeze.
sorens2 - 19/10/11 at 06:51 PM
Antifreeze is activated by water so 50:50 is the best.
Just checked mine.
-45 deg.
S๘oren S2
Ninehigh - 19/10/11 at 07:08 PM
So you couldn't have just pure antifreeze in the wine, er, I mean rad?
I thought it had to be a mix because antifreeze was rather corrosive to radiators...
I've got that episode of the simpsons stuck in my head now where he gets sent to france.
"Antifreeze dans le vin?"
flibble - 19/10/11 at 07:08 PM
^^ He's right ya' know!!
Didn't realise that was how it worked either, so had to go look it up
sorens2 - 19/10/11 at 07:14 PM
Thats Ethylene.
There are other types but generally its 50:50
And antifreeze is also added because of its anti corrosion additives.
Pure water is poison to your rad and engine.
Soren S2
perksy - 19/10/11 at 07:17 PM
I'd go 50 : 50
T66 - 19/10/11 at 07:25 PM
My Freelander runs a clever mix in its 6litres -
3 litres of anti freeze , and the oily residue from the time the oil cooler let the engine oil blow out the header tank.
It will never freeze - header tank looks like a beach on the gulf of mexico
britishtrident - 19/10/11 at 07:33 PM
The import thing is use the correct type of antifreeze generally pink/orange is OAT 5 year+ longlife coolant , and blue/green is old fashioned ethylene glycol 2year life antifreeze. They shouldn't be mixed because the corrosion inhibitors are incompatible.
These aren't the only variations for instance Asian manufacturers used a Red ethelene glycol coolant, and you wil also HOAT coolant.
Some coolants particularly some HOAT coolants claim they can be used mixed with either type however if you want extended coolant life you must flush the old fashioned antifreeze out the system completely.
Also when buying particularly if buying from a supermarket take care to check if you are buying pre-mixed coolant or raw antifreeze concentrate.
Remember also that antifreeze will increase coolant leakage, so carefully check foe leaks.
[Edited on 19/10/11 by britishtrident]
britishtrident - 19/10/11 at 07:46 PM
Originally posted by sorens2
Thats Ethylene.
Soren S2
That is the only because of the corosion inhibitor that are added to antifreeze, the inhibitors degrade with time, 2 years for conventional antifreeze 5 to 10 years for longlife OAT coolants.
Going back a few decades most antifreezes were much more corrosive than tap water because they often contained methanol at anywhere from 25% to 90% and the corrosion inhibitors then in use only had short life and the coolant had to be replaced with water during the summer months.
T66 - 19/10/11 at 08:41 PM
Thats Ethylene.
Soren S2
I refer you to my earlier post - engine oil is a great corrosion inhibitor when mixed with anti feeeze.
Ninehigh - 19/10/11 at 10:31 PM
You know according to the book mine stays for the life of the engine and never needs replacing...
morcus - 19/10/11 at 10:52 PM
Isn't that a con though so you'll kill your car and by a new one like keeping the same transmission fluid for life?
Quick question, mine doesn't need doing but for future reference and for anyone else who doesn't know, how do you drain the system?
jossey - 20/10/11 at 08:19 AM
50:50 defo.
britishtrident - 20/10/11 at 08:27 AM
Oil films on the internal surfaces of the engine and radiator has bad effect on heat transfer
britishtrident - 20/10/11 at 08:30 AM
I think they work on the theory that top ups and partial coolant changes keep the concentration of corrosion inhibitors high enough.
