OT: Tintop Brake Disc and Pad "Upgrades"
SeaBass - 15/9/09 at 09:04 PM
The time has come to replace the front discs and pads on the daily driver.
I've been considering an 'upgrade' but every review I read tells a different story. Anyone used any EBC Green Stuff Pads.
I'd like better brake feel but don't want to go balls out to a race compound for obvious reasons. Any suggestions for pads discs that work??
Or should I spend my money on decent ATE OEM parts which seem cheap in comparison.
JC
tomgregory2000 - 15/9/09 at 09:07 PM
I had some greenstuff pads fitted to my corrado and brembo max(i think thats what they were called) disc's
They were fantastic but that was 3 years ago and i think they have changed the compound now
paul the 6th - 15/9/09 at 09:11 PM
i fitted some greenstuffs to the missus' fiesta zetec-s tdci (07) and they were a fair improvement over standard.
I also use ebc HH sinterred pads in my suzuki sv1000 = fantastic improvement, much more initial bite & then lots of feel
mookaloid - 15/9/09 at 09:17 PM
I think a fair bit depends on what car it is
austin man - 15/9/09 at 09:48 PM
seen greenstuff on a an Indy , they stopped it on a tanner
Ninehigh - 15/9/09 at 10:09 PM
Not used them but I looked on tinternet when my tintop needed replacements and they were cheaper (including delivery) than Halfrauds!
If I can find the link I'll post it here
Yeah got it here , the Halfrauds ones were £54!
[Edited on 15/9/09 by Ninehigh]
speedyxjs - 16/9/09 at 06:03 AM
Iv been reccomended greenstuff pads for my tintop. I will be changing them over as soon as i have some money.
alistairolsen - 16/9/09 at 07:16 AM
conversely to this post ive never heard good reports of greenstuff lol. The usual suspects are mintex 1144s and ferodo ds2500.
Personally if its a daily driver Id be going with oe spec mintex pads (red box) and some motorfactors disks.
Rob Palin - 16/9/09 at 07:23 AM
I tried EBC RedStuff on my old Impreza and they were truly awful. Absolutely rubbish on the road and equally hopeless on track (so cold + hot).
I swapped them for the very expensive (£150ish) Pagid Blues and the difference was incredible. Pagid are pricey but their performance is in a different league. They didn't wear the discs as hard as I was warned, either (30k miles with no problems).
I use EBC Green Stuff on the race car, having also tried Ferodo DS2500 and Mintex 1144. The GreenStuff have been the best of the three, but I don't know how well they'd cope on a heavier car.
britishtrident - 16/9/09 at 07:50 AM
Depends on the car for a road car generally stick to OEM quality pads --- ie first line pads, as with tyres brake friction manufacturers have first and second lines.
With discs it is generally round ones that work best --
Biggest single improvement you can make to brakes is to change the fluid every 2 years.
[Edited on 16/9/09 by britishtrident]
MikeRJ - 16/9/09 at 09:29 AM
The Greestuff pads are little better than most OEM pad materials, though quite a lot better than some of the crappy unbranded pads.
I will second the suggestion of the 1144 and DS2500, both excellent pads for fast road use with no cold braking problems. They are quite a bit more expensive than EBC pads, but you get what you pay for in this instance.
DRC INDY 7 - 18/9/09 at 09:06 PM
ihave just fitted some greenstuff pads just need to try them now
