zetec - oil around plugs
gdp66 - 29/5/10 at 06:14 PM
any idea how this much oil could be around the plugs.
Cleaned it up, driven it for a few miles all seems ok.
the gasket on the cam cover was ok, and tight.
oil
will121 - 29/5/10 at 06:30 PM
as its at the top of the casting above the plugs can only see coming from cam cover gastet or crack in cover?
gdp66 - 29/5/10 at 06:43 PM
the hole where the plugs are is almost full to the top.
zetec - 29/5/10 at 06:57 PM
Agree about cam cover gasket, only real place. The gasket is easily twisted when in place and that amount of of oil coming through a crack is a lot!
fatbaldbloke - 29/5/10 at 07:26 PM
Yep, almost certainly cam cover gasket. It's worthwhile buying genuine Ford, I've known cheaper copies to swell and become porous.
Werner Van Loock - 29/5/10 at 07:58 PM
and tighten the rocker cover bolts up to specified torque and not by guessing or tight by hand
RoadkillUK - 29/5/10 at 08:31 PM
Definately the cam cover, ours did it last year coming home from Newark and it's now doing it again.
gdp66 - 30/5/10 at 09:23 PM
ok, cleaned up all of the oil.
Will check later if I have any new oil, as been out for 100+ miles.
