Fitting Acoust-fil
bi22le - 2/6/10 at 06:33 PM
Hi all.
I have received my length of Acousta-fil and was hoping for it to come with SOME instructions. There was nothing with it!!
I have had a quick search on the net to. You all know the deal though, if you need an answer post on LCB!!
So any pointers, advice or tips?
Im just going to clean out the silencer, roll all of the Acoust-fil around the central perferated tube and reassemble.
Start the car and stand back!
RazMan - 2/6/10 at 06:47 PM
That's basically all you do! No need to tie it onto the tube or anything like that - the 'sacrificial yarn' simply melts when working temps are achieved so it might sound a bit louder than it should for a while but a good motorway blast will sort it out. The whole can will get filled as it expands - clever stuff.
Best thing I ever did with my silencer - it gives a lovely deep, mellow tone.
bi22le - 2/6/10 at 07:30 PM
cheers. Always nice to know for certain.
bob tatt - 2/6/10 at 07:47 PM
i repacked mine last week end not been for a blast yet to get it upto temp but it sounded quieter already.
what rivets have you used to put the can back together alloy or stainless. Im only asking after reading guinness post from earlier about the end of his coming off and i have used alloy so now im worried.
easisatman - 2/6/10 at 09:21 PM
yep I have used it in my can and it does make it a bit quieter but still loud on full bore and loads of popping back on overrun. I used stainless rivets to put it back together
Danozeman - 3/6/10 at 06:28 AM
As Razman says you need to get it ho to burn the stitching off.
Mine sounds superb and it smells nice after a couple of good thrashes. Mines been in since summer ish last year and the sounds getting better.
