Would this puller be OK to remove the rear oil seal TOOLMATE US Bearing puller 3” 75mm Triple Leg Reversible Gear Hub
puller
I tried hammer and screw driver on my knackered old box, but could not get it out. Will the puller in the link above fit, or is it too big??
[Edited on 19/9/13 by puma931]
It should come out easy just collapse the seal with a hammer and screwdriver
As above no special tool needed
Managed to get it out using a hammer and chisel. it did take some bashing before it came out!!
I drilled a small hole in mine then wound a self tapper in and used a set of mole grips to pull it out.
