DIY remote gaerchange
givemethebighammer - 8/12/02 at 07:35 PM
Anyone seen any details on how to build your own remote gear change device for a ford (or any other for that matter) type 9 gearbox ? Can't be that hard to make
thanks
givemethebighammer - 8/12/02 at 07:42 PM
gaerchange, oops slipped into dutch again, I wasn't suggesting that any other manufacturer make a type 9 gearbox (although they might). Its Sunday, brain offline.
doh !!
Mr G - 8/12/02 at 08:21 PM
Try here :
http://freespace.virgin.net/d.w.jenkins/gear_extend.htm
G
givemethebighammer - 8/12/02 at 08:38 PM
Looks good, if a little complicated at first.
Once I have read it whilst looking at the gearbox it should all make sense.
thanks
stephen_gusterson - 8/12/02 at 09:05 PM
there is another way that I have seen on the net that looks a lot simpler.
I doubt I will remember where tho - so I will do a crap sketch and put it up shortly.
atb
steve
stephen_gusterson - 8/12/02 at 09:33 PM
If you look at my standard of sketching, you will understand why I gave up tech drg at 14 and became a hardware / software engineer.
The following idea is not mine, I dont know how good or bad it is. I was going to make this mod on my car, and have the gear lever to do it with. However, when I saw that its only 4 - 5 ins difference, I thought I would see what the std layout is like before I go to this hassle.
Basically, cut off the old gear lever at a point below the rubber 'bush' that acts as a vibration dampener. I remeber reading that you can free the bush if needed by heat - ie torch it.
Inside the box somewhere where the lever comes off is a metal 'tang' - or it could be on the lever itself - that acts to prevent reverse selection unless the lever is pulled (or pushed?) in the right direction to overcome the 'stop'. You have to take this off.
I cant remember how to re-instate it at the remote lever - but I am sure you can work out a way or be careful!
To the original lever shaft, weld a bracket - a bit like the one on the suspension. Weld it with as much bracing as you can
as this will take some 'leverage'. (really!)
Drill through a suitable rod (or use tube) which you weld a length of flat bar - say 30mm x 5mm to the drilled metal 'bush'. This bolts to the bracket in such a way that it is allowed to pivot to allow forward and backward movement - ie - lets you select 1st or second.
you dont want this sloppy in the left right direction or your gearchange will feel crap.
Now, modify a second gear lever to have a similar braket at its base - be careful the welding heat does not melt the aforementioned vibration damper thingy in the lever shaft.
Bolt the flat bar linkage via a second metal tube/bush to the bracket at the other end.
You now have a gearchange extension. I think if mounted low, you could hide all this in the tunnel or an extended cover over it.
I remember a note about using flat bar instead of rod as the linkage as it is less prone to twisting as you move from 2nd to 3rd across the gate.
I hope this is of some use - it does not seem to need a lathe - just a few bits of steel, a drill and a couple bolts and a welder.
atb
steve
[Edited on 8/12/02 by stephen_gusterson] Rescued attachment Image2.jpg
locodude - 8/12/02 at 10:18 PM
Same as mine, works a treat. Made a gate for the gearchange lever so don't need a reverse detent, just knock the stop out of the remote housing, and hey presto!
David Jenkins - 9/12/02 at 08:58 AM
thanks
Yes, it is more complicated that Steve's linkage - but it all fits within the tunnel, has the reverse detent where it's supposed to be, and the reverse light switch works!
It operates by extending the gearbox main selector shaft. You need a lathe for the extension pice, and for its bearing, but apart from that it's sheet metalwork.
regards,
locodude - 9/12/02 at 07:02 PM
Reverse light , what reverse light, just adds more weight, don't need it, don't fit it! says he who's car is 30kg heavier now than when SVA'd
chrisg - 9/12/02 at 09:39 PM
Got a Fog light though Chris................eh?
Chris
locodude - 10/12/02 at 06:26 PM
I presume our resident sarcasamist means fogleet!
chrisg - 10/12/02 at 07:23 PM
yes, out with the lip balm!!!
Chris
givemethebighammer - 10/12/02 at 08:44 PM
Meanwhile back at the workshop...
After reading this
and looking very closely at my gearbox. It is not as complicated at you would first think.. I'm off find a lathe
thanks guys
phil - 10/12/02 at 09:04 PM
While taking out some bedford rascal seats, i took a shine to the h/brake lever and removed the console , sitting underneath was the gearlever mounted remotely via cables. If i hadn't used a similar method to Steve's then i would have tried to use the rascal one, sorry don't know what the g/box cable ends are like , but must be worth a look if your desperate. good luck Phil.........
stephen_gusterson - 11/12/02 at 10:02 PM
Suppose it must work on the Rascal, but I would have thought it was quite hard to make up a cable system that didnt have a fair bit of 'backlash' in it?
atb
steve
Stu16v - 11/12/02 at 11:21 PM
Quite a few commercial vans use 'cable change'. Another car to use it was the first Maxi's......
Dont larf, quite a few of you have Maxi bottom ball joints......
David Jenkins - 12/12/02 at 09:01 AM
After reading this
thanks guys
...and don't forget, it can be as long as you like! (Ooer, missus!)
David Jenkins - 12/12/02 at 09:03 AM
I'm going for ultra-convenient, not ultra-light, so I don't really care about an extra 2 ounces of plastic and wire...
DJ
bob - 12/12/02 at 09:29 AM
And dont forget the BEC boys use the cable linkage
jmbillings - 12/12/02 at 11:53 PM
We used Steves "bar" method (but with square section tube). MK also suggested this way. Works a treat. One thing we did is to not grin off the reverse stop altogether but just file it a bit- if you have ever driven a BMW, you will know what its like- there is resistance to push it across to Reverse, but you dont actually have to push it down.
stephen_gusterson - 13/12/02 at 08:06 PM
yep - i do know what the 318 is like - when I took delivery of it it almost needed two hands to put it in reverse! freed up after a while.
atb
steve
Peteff - 14/12/02 at 12:39 AM
I used a type 9 gearbox and a 2ltr pinto and the gear lever is in the ideal position without any modification. What you need is longer arms or mount your engine further back.
yours, Pete.
