Author: Subject: brake size
Stuart_B
posted on 5/11/08 at 08:41 PM Reply With Quote
brake size
hi all, what is the biggest brakes you can fit in 15" rims? can you fit Cosworth front brakes in?
thanks
stuart
eznfrank
posted on 5/11/08 at 09:00 PM Reply With Quote
I have on mine but some would say it's overkill.
Stuart_B
posted on 5/11/08 at 09:03 PM Reply With Quote
yes it may be over kill, but i just want to make sure it stops when i wont it to. so as long they fit, i will try and get a set.
thanks
stuart
philw
posted on 5/11/08 at 09:27 PM Reply With Quote
Standard 247mm escort discs with wilwoods will be fine, however if you have the right 15" wheels you can get 310mm discs on there i have a set and the look delicious but a tad big
http://www.locostbuilders.co.uk/photos.php?action=showphoto&photo=brakescar%20002.jpg
The photo is a bit big.
[Edited on 5/11/08 by philw]
Must try harder
Stuart_B
posted on 5/11/08 at 09:31 PM Reply With Quote
i have the smallest disk on the front of the mk and they just look a bit small. and the 4 pot cosworth calipers looks nicer and will stop better with them.
thansk
stuart
philw
posted on 5/11/08 at 09:40 PM Reply With Quote
The reason people go for wilwood callipers is they save so much weight.
Must try harder
mcerd1
posted on 6/11/08 at 08:32 AM Reply With Quote
but the cosworth 2wd iron 4 pots could sink a battleship
btw I've got a set of cossie 4 pots (in need of a recon) if anyone wants them
