Sideshow_Bob
| posted on 22/11/08 at 06:36 PM |
Atlas Axle help
I bought an Atlas axle a while ago, and bought some axle brackets for it. However, the axle brackets didn't fit. The hole cutout in the centre
was too large. I have measured the diameter of the axle and it is 58.4mm (2.3" I understand that Atlas axles are 70mm (2.75" . If that is
the case ...what axle have i got? Does the baby Atlas have a smaller diameter axle?
blakep82
| posted on 22/11/08 at 06:38 PM |
my atlas is 70mm, but i did retube it with bigger heavy duty tubes, can't remember what they were originally, but 58mm sounds about right. mine
was off a 2 ltr capri, so you quite possibly have got an atlas, just not a retubed one. grp 4 atlas axles are usually 70mm
[Edited on 22/11/08 by blakep82]
________________________
Sideshow_Bob
| posted on 22/11/08 at 06:42 PM |
Thanks blake,
The reason I'm asking is I want to do a rear brake conversion on the axle, and have seen the weld on brackets on a few sites, but reckon they
won't fit given previous experience.
Does anyone know where i might be able to get hold of some drawings for the axle?
big_wasa
| posted on 22/11/08 at 06:43 PM |
Standard atlas axle is about 58mm.
I bought a pair of book ie english brackets from OBP and they fit just fine.
blakep82
| posted on 22/11/08 at 06:47 PM |
ah, now i bought english axle brackets for my retubed atlas because they were 70mm. they are from shortrack on here
short track 123
| posted on 23/11/08 at 06:14 AM |
Hello
Our disk brackets are made to bolt onto the back of the bearing flange some people do weld them as well and some just weld which means you can change
the angle if you need to. If you measure the diameter of the flange where it meets the axle tube it should be about 70mm and the axle tube will be
58.4mm as you say. The important part is the off set of the disc and the caliper you are using.
I can make you some one off brackets if you want if they are made from the same material as the ones we make they will be the same cost as the one we
sell. Just Email a drawing/or pic and the size of disc you would like to use and i can sort the rest out for you.
Which ever way you go mock it all up 1st before welding ( if you go the welding route )
Hope this is of some help to you
Jason
Shorttrack MotorSport Ltd
Avoneer
| posted on 23/11/08 at 09:32 AM |
Off topic, but can you cut single exhaust outlet flanges in stainless?
Pat...
blakep82
| posted on 23/11/08 at 12:49 PM |
of course, i forgot jasons brackets are made to bolt on
Sideshow_Bob
| posted on 23/11/08 at 01:18 PM |
Hey thanks for the replies guys,
Jason, I'm planning on using sierra rear calipers (well actually off a ford scorpio), so it looks like your brackets would do the job. do you
also sell the spacers to replace the drum brake back plates.
carpmart
| posted on 23/11/08 at 03:22 PM |
u2u sent as I have a rear disc conversion for sale.
'94 MX5 MK1, 1.8
F10 M5 - 600bhp Daily Hack
Mercedes A class - Son's Car
short track 123
| posted on 23/11/08 at 04:33 PM |
Pat
Yes I can what sort do you want.
carpmart
Who's the kit made by and how much?
We can now scan drawings/gaskets/templates which means we can do 1 off parts but if we can try and batch things it does make all the parts cheeper.
I don't charge for the drawing work as long as we make the parts.
Regards
Jason
