Author: Subject: Steering Column
dave107
posted on 25/3/09 at 11:24 PM Reply With Quote
Steering Column
I have an MNR Vortx, has anyone got a photo of their Sierra steering column in the area around the fixing point with the two holes showing the large spring and aluminium block, as mine seems to have a lot of slack almost as though the round plate welded on the column is to low by about 50mm.
jambo
posted on 25/3/09 at 11:47 PM Reply With Quote
i had the same problem,i had this as i was using an adjustable column from the sierra and mnr's paddle shift column.
is your column from an adjustable sierra?
dave107
posted on 26/3/09 at 08:34 AM Reply With Quote
Thanks for reply.
I am using it with paddle shift, also with the column i have two round aluminium bars with a hole through the centres and they fit inside the two holes in the aluminium block, but one is longer than the other did you have these as well if you understand what i am going on about.
I don't know if it's from adjustable i will have to ask Chris at MNR.
What did you have to do to get over problem
