Author: Subject: steering linkage downshaft
ernie
posted on 20/2/04 at 06:09 PM Reply With Quote
The book shows a shaft with top & bottom uj `s to fit escort column & rack to be modified to suit, what does it come from and whre can I get one
Mark Allanson
posted on 20/2/04 at 07:28 PM Reply With Quote
Assuming you are using a sierra column, I used the lower column from a power steering sierra which is 19mm round tube, but the lower joint is too big for an escort rack. So I drilled out the rivets on the donut and attached the lower clamp from a manual steering sierra and replaced the rivets with M8 HT setscrews.
If you are not using a sierra column, I'll pass, and someone else will help you
theconrodkid
posted on 20/2/04 at 08:29 PM Reply With Quote
proper metal u/j,s are from an allegro,people like raldes do after market ones tho
who cares who wins
pass the pork pies
