cloudy
| posted on 26/4/09 at 10:24 PM |
Rubbery squeak after driving
My rear left wheel bearing (disc sierra) has a rubbery squeak when you push the car around after a drive. It's much like a polybush squeak but
quieter - I would guess its the oil seal.
Hub does not get hot, is it worth stripping down? What could cause this?
James
www.warnercars.com
A1
| posted on 26/4/09 at 10:28 PM |
id probably say that as long as everything is running okay, its probably not worth it...just keep an eye on it and see if it gets worse.
cloudy
| posted on 26/4/09 at 10:31 PM |
I like your thinking
James
www.warnercars.com
Hellfire
| posted on 26/4/09 at 10:36 PM |
I would still say it's a polybush squeak!
Hellfire
| posted on 26/4/09 at 10:37 PM |
If it gets worse when it's warm - it most certainly will be...
cloudy
| posted on 26/4/09 at 10:40 PM |
It's not a bush, it's the wheel bearing - I was just trying to describe the squeak!
www.warnercars.com
MikeRJ
| posted on 27/4/09 at 08:46 AM |
You sure it's not the pads touching the disk from e.g. a sticky caliper?
cloudy
| posted on 27/4/09 at 08:51 AM |
Yup
www.warnercars.com
| posted on 27/4/09 at 10:36 AM |
Is it your trainers squeeking on the garage floor with the effort of pushing the car....?
