Author: Subject: Diff Play
Daddylonglegs
posted on 19/5/09 at 12:37 PM Reply With Quote
Diff Play
Right,
Rebuilt the diff/axle and now the car is on the ground, when I turn the pinion flange, it moves a few mm before it takes up the drive.
I know that the backlash has to be set in the diff, and I set it as best I could without the actual figures, when I adjusted the crown wheel for mesh, I backed it off one notch (on the locking plate) from when it was slightly binding (a slight tight spot on the crown wheel I think). It seemd OK so I rebuilt everything and fitted it to the car.
Can anyone tell me how much freeplay is acceptable in the input before taking up the drive.
JB
tegwin
posted on 19/5/09 at 12:42 PM Reply With Quote
On my TR diff the backlash is around "5 mins" if you imagine the flange as a clockface...apparenly thats normal
www.verticalhorizonsmedia.tv
posted on 19/5/09 at 12:57 PM Reply With Quote
I've got quite a degree of backlash in my diff. Makes a nasty crunching noise when it takes up the backlash as well Never measured it but it makes me winse!! Still hasn't broken yet though
blakep82
posted on 19/5/09 at 01:28 PM Reply With Quote
before i took my atlas apart, i had about 5 degrees.
________________________
Daddylonglegs
posted on 19/5/09 at 02:20 PM Reply With Quote
But why did U take it apart? Was it because of the backlash or something else
JB
bimbleuk
posted on 19/5/09 at 03:16 PM Reply With Quote
The one in my car has probably 10 degs of play and definitely clonks on take up. Just a little too loose for my liking but. I've another second hand one untouched and that has less and another which was a recon unit and has 3-5 deg at most.
Daddylonglegs
posted on 19/5/09 at 03:19 PM Reply With Quote
Maybe I'm being a worry wart for no reason then?
I'll try and measure the play tonight and put the result on here.
JB
Daddylonglegs
posted on 19/5/09 at 09:22 PM Reply With Quote
Measured it tonight and I reckon 5-6 degress. So I guess I'll leave it and see what occurs when the glorius day comes
