Author: Subject: help M18 Rose Joints and sierra bearings.
ashg
posted on 30/5/09 at 09:55 PM Reply With Quote
Hi guys
i have looked everywhere without any luck
were can i get m18 1.5 fine rose joints to fit my rally design quick camber adjusers.
also where is the cheepest place to purchase replacement sierra front hub bearings the local motorfactor wanted £18 a side is this a reasonable price?
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
blakep82
posted on 30/5/09 at 09:57 PM Reply With Quote
http://stores.shop.ebay.co.uk/McGill-Motorsports_Metric-Male-Rose-Joints_W0QQ_fsubZ5570178QQ_sidZ222097034?_nkw=M18
________________________
dinosaurjuice
posted on 30/5/09 at 09:59 PM Reply With Quote
ebay linky for mcgill motorsport.
ive used there stuff on steering and gear linkages and seems good quality. not sure about using a £12 rose joint on suspension...
edit: Blake!! you keyboard demon
[Edited on 30/5/09 by dinosaurjuice]
blakep82
posted on 30/5/09 at 10:01 PM Reply With Quote
i'm too quick!
so the girls tell me....
hellbent345
posted on 30/5/09 at 10:05 PM Reply With Quote
"not sure about using a £12 rose joint on suspension..."
indeed, but what are others experiences of these joints for suspension use? i was looking at buying m16 joints for about 180 quid, if these would be a reasonable low milage alternative, ie 3 sets would last as long as one set of the higher cost ones or better, so it would be more cost effective to buy the cheap ones?
edit to add quote, blake was too quick for me to reply right underneath!!
[Edited on 30/5/09 by hellbent345]
dinosaurjuice
posted on 30/5/09 at 10:13 PM Reply With Quote
i wasnt knocking the quality, i just have no experience of using rose joints on supension so im not really in a position to give out advice
blakep82
i have nothing better to do with my time...
ashg
posted on 30/5/09 at 10:14 PM Reply With Quote
ok have ordered those ones. they are for the rear upper wishbone camber adjuster.
i am only getting them as i cant find m18 1.5 studding to make normal bushed camber adjusters
hellbent345
posted on 30/5/09 at 10:18 PM Reply With Quote
Sorry chap, wasn't saying you were, i was more saying i cant trust the quality lol how can i get the same thing for 50 and 180 somewhere else...? something must be different i recons
blakep82
posted on 30/5/09 at 10:19 PM Reply With Quote
i hope they're alright, my whole suspension is made of them. the thinking behind it is they were cheap to get the car built up. if they wear too quick or whatever i'll replace them with expensive ones when they need it. if they turn out good, i'll get some more
hellbent345
posted on 30/5/09 at 10:23 PM Reply With Quote
good enough for me, ill get them then! i dont need much persuasion to save 130 quids!!
Thankin you
Al
blakep82
posted on 30/5/09 at 10:26 PM Reply With Quote
i've not driven my car with them yet btw!
but i've spoke to billy himself, he supplies to all the stock car racers at cowdenbeath, i tend to think the stress put through them is likely to be more on race car suspension. but have a look at the load data on his page, and compare to others.
James
posted on 31/5/09 at 07:33 AM Reply With Quote
I made mine from cheap transit drag links that we use for the front upper balljoints!
They're really cheap from Lolocost, I just cut off the head and used the threaded bar piece. I welded a bush tube to the end of this.
That meant I could easily get some 18x1.5mm threaded tube to use for the rear wishbones too.
Hope that makes sense.
James
ashg
posted on 31/5/09 at 10:31 PM Reply With Quote
thats my plan im going to use the rose joints and if they dont last i will cut the thread ends off and weld them to the bush tubes.
