cd.thomson
| posted on 2/6/09 at 12:09 PM |
brake resevoir and connections
Hi guys, my question for today centers on sourcing a resevoir for my master cylinders (0.625 and 0.7) and getting everything connected up.
I understand the resevoir must be IVA compatible, does this mean it requires a low level switch? Does this appear suitable:
linky
I also require the connections to link the m/c to the resevoir, does anybody know what fittings the wilwood cylinders use? I dont think its these:
linky
Craig
handyandy
| posted on 2/6/09 at 12:40 PM |
yes the way i understand the iva rule is that it must have a low fluid warning function & so that resevoir looks suitable.
sorry i don,t know anything about wilwood brakes.
andy
blakep82
| posted on 2/6/09 at 02:25 PM |
you already had your question earlier! :p
wilwood MCs have a 7/16 unf fluid inlet, so those fitting should be fine, as is that resevoir
________________________
cd.thomson
| posted on 2/6/09 at 02:29 PM |
my question earlier wasnt about the car so it didnt count! thanks for the response
Craig
stevegough
| posted on 2/6/09 at 08:02 PM |
Craig -
drop pipes and resevoirs - depending what room you have got, - bit tight around your clutch arm,I know, but this is how I've done mine. The
level switches are from rally design.
Regards, Steve.
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
