mcerd1
posted on 10/6/09 at 08:43 AM |
Sierra 'push-in' shafts / steering rack ?
I found these while clearing out the garage:
I think they are off my dads old sierra 2.0 pinto estate (I must have been about 9 years old when he sold it!)
other wise they came from a 1.8 CVH one (which he sold when I was 16)
so either way they've been there a while :lol:
the driveshafts are ~27mm dia. in the midle of the shaft itself
and ~28mm dia. on the splines where they fit into the diff
so what else do I need to check to find out what they are?
Marcus
| posted on 10/6/09 at 11:26 AM |
That rack looks Cortina ish..ISTR all Siera ones had an alloy casing.
Marcus
Because kits are for girls!!
mcerd1
| posted on 10/6/09 at 11:29 AM |
if its not a sierra one, it could be a cortina one, he had a few of them too
but it could be from almost anything :?
in the past I've found a dead cortina back axle, a dead talbot sunbeam back axle, a 2.0 pinto, pre-historic SU carbs, alfa hubcaps, talbot 90
gearboxes and about 40+ wheels (inc 1 set of origonal 10" mini cooper steels )
and loads of other bits for roots group, pug/talbot and ford cars.........
all my donor cars have been granada's or XR4x4, so all have bolt-on shafts and power steering - which means I've nothing to compare them
to.......
[Edited on 10/6/09 by mcerd1]
redscamp
| posted on 10/6/09 at 11:42 AM |
sorry some sierras did have steel cased steering racks (P100 at the very least)
the bolt through hole mounts sugest sierra rack
and rule out cortina
mangogrooveworkshop
| posted on 10/6/09 at 04:53 PM |
will be over for the car soon
mcerd1
| posted on 10/6/09 at 05:40 PM |
I was going to send you a text about that
I acually need to shift it before the end of the month (I've been told it needs to go before the weddding next door)
