greggors84
posted on 12/3/04 at 11:08 AM |
Brake Pipes in the Engine Bay
I have routed my rear brake pipe out of the M/C and around the bulkhead, but near the bottom, around the same level as the M/C, just wondering if
there will be any problem due to heat, from the engine or gearbox, dont want my brake fluid boiling! If there was a problem, could i solve it by
putting a better brake fluid in?
Chris
The Magnificent 7!
Mk-Ninja
posted on 12/3/04 at 11:10 AM |
You should be OK as long as you keep it away from the exhaust.
I'm sure I've got one, just don't know where I've put it
Terrapin_racing
posted on 12/3/04 at 11:56 AM |
If you are still worried you can get heat reflective sleeving for the brake pipes.
www.thinkauto.com
