ned
| posted on 15/3/04 at 12:49 PM |
longer wheel stud length for alloys?
I have my cortina hubs with original studs in, but understand they are a bit short for my alloys as there won't be enough thread for the nuts to
hold onto. Anyone know what length replacement studs i need to order from raldes?
i'm getting near rolling chassis stage, so would be nice to know so the wheels fitter propper like!
Ned.
beware, I've got yellow skin
flak monkey
| posted on 15/3/04 at 01:53 PM |
I seem to remember someone saying to replace the cortina studs with sierra ones....or was i imagining it?
Sera
http://www.motosera.com
Berwyn
| posted on 15/3/04 at 01:57 PM |
Dont forget the more important bit, the taper ! I used the original nuts on my TSW alloys and neary knackered them as the taper in the wheel was
different to the one on the nut.
Better off investing in some new nuts to matched the taper in your alloys.
ned
| posted on 15/3/04 at 01:58 PM |
i have the nuts!
i also have some sierra uprights kickng about, so will swap the studs over. nice and cheap!
thanks!
Ned.
Deckman001
| posted on 15/3/04 at 02:09 PM |
Any one know how much thread is needed through the wheel, to do the nut up proper like !!
Jason
Staple balls
| posted on 15/3/04 at 02:20 PM |
i *think*that on bolts/nuts you need a full 3 turns (at least) for saftey. not sure though
Mix
| posted on 15/3/04 at 04:17 PM |
As a rule of thumb for a standard nut to be 'in safety' the thread of the bolt should protrude 1.5 threads. I know a lot of wheel nuts are
closed but if you look at a standard nut that will fit your wheel studs then that will give you a good indication of the thread engagment required,
(add a bit to allow for the taper). I would always err on the long side for peace of mind.
SB
I would strongly advise you never to consider three turns to be sufficient.
Mick
[Edited on 15/3/04 by Mix]
James
| posted on 15/3/04 at 04:36 PM |
quote: Originally posted by ned
i have nuts!
I removed my studs to clean the hubs more easily- getting them out was hard... getting them back in nearly killed me!
At one point I nearly simultaneously broke the workmate, the vice and my foot all in one fell swoop!
James
wicket
| posted on 15/3/04 at 04:45 PM |
Have a look at this recent thread, also about studs and wheel nuts.
http://www.locostbuilders.co.uk/viewthread.php?tid=11343
[Edited on 15/3/04 by wicket]
Alan B
| posted on 15/3/04 at 04:57 PM |
IIRC the 3 thread thing comes from 3 perfect internal threads engaging on 3 perfect external threads carry something like 90 odd % of the load...the
rest beyond 3 add virtually nothing...
I am sure it is theoretically correct, but in the meantime I'll be looking for a lot more threads engaged.
When I was at Rockwell the rule for thread engagement was 1.5 x D into holes that were 2 x D deep...i.e. a 10mm screw to engage 15mm (min) into a 20mm
deep (min) hole.....I still follow this rule of thumb
Deckman001
| posted on 15/3/04 at 06:20 PM |
Cheers guys, that clears it up loads, will have to order some new studs then, Bugger
Thanks for the info tho, better to know now than later !!
Jason
elitewiring
| posted on 16/3/04 at 01:16 AM |
parts guy at ford main dealer said hes had kitcar owners in asking for this before, and he said that granada studs would do the job, he was totally
correct, i think they were about 75 pence each.
minilight style wheels fitted to mine.
Deckman001
| posted on 16/3/04 at 07:30 AM |
Wicket, just read the post you linked to , sorry, seams like you are doing the same as i intend, RS alloys onto the cortina hubs, I take it you
didn't get away with std studs, did you get them from Rally design along with the nuts, I have the nuts, just need the studs ( incase anyone has
a spare set that wicket describes )
Jason
