david
| posted on 24/7/09 at 08:24 PM |
caster
Where do I take the readings from to get the caster. I have a unit that measures caster and camber and kpi. It has a magnet and locks on to the
wheel or disk and you set it up with turning a dial round and setting a bubble between two lines. Cant get a manual so I am working in the dark. The
camber is easy to set and when checked with a lazer was 100 per cent. David. Any one used this type of machine
| posted on 24/7/09 at 08:29 PM |
castor is the line between top and bottom ball joints when viewed from the side. Best bet with your magnetic thing is to stick it on and line it up as
best you can. The reading will be slightly affected by camber but not much.
