Author: Subject: Diff/speedo ratios
norm007
posted on 3/8/09 at 02:54 PM Reply With Quote
Diff/speedo ratios
I have swapped my 3.62 ratio diff to a 3.92.
Could anybody tell me how to work out how much faster my speedo will be reading than the actual speed?
Something about this, so very wrong.....I have to laugh out loud, I wish I didn`t like this!!!!!!!!!!!!!!
mcerd1
posted on 3/8/09 at 03:13 PM Reply With Quote
3.92 / 3.62 = 1.08
=> you speedo is showing +8% faster than your really going
e.g. your speedo says 60, but your really only doing 55.5
or try this http://locost7.info/gearcalc.php
[Edited on 3/8/09 by mcerd1]
asl
posted on 3/8/09 at 03:21 PM Reply With Quote
Ok, I am going to make myself look like a complete t#*t but I have to ask this......... I changed my diff from a 3.92 to a 3.38. Has this affected my speedo?
mcerd1
posted on 3/8/09 at 03:26 PM Reply With Quote
yes
3.92 / 3.38 = 1.16
=> you are going +16% faster than your speedo says (assuming it was right before the swap)
so if your speedo says 60, your really doing 69.6
try the gear calc program above ^^^
aka Keith
posted on 3/8/09 at 03:27 PM Reply With Quote
Nat, great post. in a word yes, your actual speed will be more than your indicated speed.
cheers
Craig
You will need to recalibrate your speedo, so as not to pick up any speeding tickets.
[Edited on 3/8/09 by aka Keith]
asl
posted on 3/8/09 at 03:34 PM Reply With Quote
Bloody hell, you learn something everyday! That will explain why when I took my dad out he was commenting and how it feels like we were goin much faster than we actually were!! From numpty of Guildford!
James
posted on 3/8/09 at 04:08 PM Reply With Quote
Especially worrying with the new mobile speed camera in Guildford!!!
mad-butcher
posted on 3/8/09 at 06:52 PM Reply With Quote
well I'll throw a spanner in the works, I can change my diff without having to recalibrate my speedo.
why you might ask, cos I take my pulses from the driveshaft which only requires rolling distance on the acewell,
tony
matt_claydon
posted on 3/8/09 at 06:54 PM Reply With Quote
Depending on where your speedo pickup is of course. If it's on the axle or wheel then diff changes will make no difference. If it's on the prop or transmission then it will make a difference.
Edit: ^ beaten to it
[Edited on 3/8/09 by matt_claydon]
mcerd1
posted on 3/8/09 at 07:56 PM Reply With Quote
tony
well remembered, I knew I'd forgotten something
norm007
posted on 4/8/09 at 11:19 AM Reply With Quote
Originally posted by mcerd1
3.92 / 3.62 = 1.08
Thank you very much for the reply.
Forgot to say that I am running cable driven speedo on Type 9, that I know was deadly accurate from rolling road session.
Could I just swap the drive gear in gearbox? If so, could you tell me which gear I would need?
