adithorp
| posted on 11/8/09 at 04:35 PM |
Sierra drive shaft Q?
Has anybody got a Sierra push in driveshaft handy to have a look at? Are both inner and outer CV joints spring loaded?
The reason I ask is because I've got a Freelander diff. The Freelander inner joint is floating, not spring loaded and the sierra outer joint is
pushing the shaft hard, one way and causing a knock. I have a cunning plan, but need to know if both Sierra joints are sprung. The manual looks like
they are.
adrian
http://jpsc.org.uk/forum/
flak monkey
| posted on 11/8/09 at 04:37 PM |
Both are sprung yes
Sera
http://www.motosera.com
t16turbotone
| posted on 11/8/09 at 05:01 PM |
sorry to hijack thread but, have you converted to freelander diff? i heard that they are lsd and 3.1?? ratio, has anyone converted from sierra to
freelander? ratios on ford diff just no good for me. thanx
much of a job??
tony
adithorp
| posted on 11/8/09 at 05:06 PM |
much of a job??
tony
No, had it in from the start. It's 3.21:1 and mines got a quaif ATB in it. I've got an open one if your interested (swaped for the ATB).
Mounting points should be easy enough to do. You've just got to get the shafts converted. Mine came already done but, as you might tell from the
thread, I'm improving the design.
