Author: Subject: setting up caster
david
posted on 30/10/09 at 01:30 AM Reply With Quote
setting up caster
what is the correct way to set up caster. Have wheels on floor with full weight car on them or jacking up the car on the chassis. David
blakep82
posted on 30/10/09 at 01:41 AM Reply With Quote
full weight on the floor (unless you plan to drive the car with the wheels off the ground a lot? )
________________________
Frosty
posted on 30/10/09 at 09:18 AM Reply With Quote
Set it in the air but measure it on the floor with the suspension settled (I always roll the car back and forward a couple of times before measuring anything just to eliminate tyre stiction).
I don't think you would have to do it for caster, but it certainly won't hurt.
Hellfire
posted on 2/11/09 at 06:50 PM Reply With Quote
Either. Just make sure the car is level front to rear unless you're using equipment to compensate for this.
Phil
