<<  1    2  >>
Author: Subject: An Old Chestnut... Bike Brakes on Se7ens!
russbost
posted on 17/11/09 at 05:32 PM Reply With Quote
Just another thought, if you're really concerned about the possibility of a disc fracturing, I'm sure someone on here can work out the shear strength of a 5mm disc - personally I'll be gobsmacked if it's not at least 3 times what you could ever actually put thro' the disc in braking terms!
I could have done it for you at one time, but my college days are a few years ago now!
tegwin
If the callipers are two part, can you not just put an alloy spacer between the halves.... some car brakes come like that as standard!!
That way you can use the bike calipers with a slightly thicker disk??!?? Would make it easier to fit a handbrake mech as well if there is a little more space to play with!
www.verticalhorizonsmedia.tv
Fred W B
posted on 17/11/09 at 05:50 PM Reply With Quote
My effort here
9 mm discs, which I plan to use with early golf GTI rear calipers
Fred W B
[Edited on 17/11/09 by Fred W B]
You can do it quickly. You can do it cheap. You can do it right. – Pick any two.
Wadders
posted on 17/11/09 at 06:06 PM Reply With Quote
I don't think fracturing would be such a problem, more likely to warp.
Al.
mcerd1
posted on 17/11/09 at 06:52 PM Reply With Quote
Originally posted by jacko
Have a look at the car grass track world
a lot of people use bike brakes my mate used them on his race car
Jacko
and formula student
MikeRJ
posted on 17/11/09 at 06:55 PM Reply With Quote
Originally posted by ed1801
Kinetic energy is 0.5 x mass x velocity squared
An R1 can do 190mph, and in doing an emergency stop from that would put 1.8 times as much energy into the brakes as stopping a 7 that is twice the weight from 100mph... The twice as heavy 7 has to do 135mph to use the same energy to stop.
But the bike has the discs completely exposed for maximum airflow around them, a car has then shrouded within a wheel.
bigpig
posted on 17/11/09 at 06:59 PM Reply With Quote
I think they would probably warp like a bugger. Decent sports discs are fully floating to reduce the chance of warpage. Bike discs can warp under normal enthusiatic use let alone the extra few hundred kilos of a car. I remember back in the late 90's is being not exactly unusual on some sports bikes.
On top of that, plenty of bike calipers are buggers for seizing and requiring new seals every few years (and that is with regular cleaning).
I think using bike calipers may well be a disaster waiting to happen. As mentioned, brakes are the thing that stops you going splat (and the person in your way). Its something I would *really* not under engineer.
Certainly I wouldn't even try it on the road without some proper investigation from an enginering perspective. You can say "sod that its too dangerous I think", but you can't do "yeah you can probably do that" then stack yourself into a tree as the brake fluid boils over and the discs are juddering like its ABS.
mackei23b
posted on 17/11/09 at 07:17 PM Reply With Quote
You should have a look at a Pilbeam, that said, they are designed for about 60 seconds use at a time on a hillclimb!
<<  1    2  >>
