Author: Subject: front brake line
bj928
posted on 18/11/09 at 10:37 PM Reply With Quote
front brake line
looking at getting my front brake lines made soon, but not sure if i need to go one piece or two, from the bracket on the chassis to the caliper is going to be about 16 inches, if i do it as a one piece i will need to clamp it in the middle to stop it floating about in mid air, if i do it in two piece i can weld a bit to the arm the same as on the chassis so as to join it in the middle, is there any rules on clamping the brake pipes ( braided type ) in a rubber innered P clip, or is there another option i'm not thinking about.
tomgregory2000
posted on 18/11/09 at 10:44 PM Reply With Quote
one piece
mine are held with zip ties to the bones, fine for sva so should be fine for iva as well
bj928
posted on 19/11/09 at 12:31 AM Reply With Quote
good enough for me, thanks
tegwin
posted on 19/11/09 at 10:51 AM Reply With Quote
Manufactured cars would use a rubber sleeve over the hose and run it through a steel ring welded to the suspension arm so it can move back and forth...
www.verticalhorizonsmedia.tv
