NS Dev
| posted on 24/11/09 at 04:17 PM |
Where to get M10 x 1 threaded plugs?
I need some M10 x 1 blanking plugs to blank off some master cylinder outlets..............any ideas where on earth I can get some!???
maximill666
| posted on 24/11/09 at 04:20 PM |
CBS do them
Linky
[Edited on 24/11/09 by maximill666]
| posted on 24/11/09 at 04:21 PM |
Could Flakmonkey make you some up?
Failing that could you cut down some stainless cap heads and use a copper washer under the head to seal them up?
adithorp
| posted on 24/11/09 at 04:25 PM |
You could try bleed nipples.
http://jpsc.org.uk/forum/
NS Dev
| posted on 24/11/09 at 04:28 PM |
Good thinking! Yep, I am a bit dim!
NS Dev
| posted on 24/11/09 at 04:29 PM |
thanks folks, quick replies! Will use CBS if I can't find any spare bleed nipples
NS Dev
| posted on 24/11/09 at 04:57 PM |
AHA!! Just for anybody else's use, Brakes International stock a specific bung that is M10 x 1 and fits the flare like a bleed nipple but without
the hole, part no. BMP100, £1.33 ea
[Edited on 24/11/09 by NS Dev]
stevebubs
| posted on 24/11/09 at 05:14 PM |
I always use Think Auto for stuff like this.
| posted on 24/11/09 at 07:21 PM |
You sometimes get one when you buy a new master cylinder, very useful when replacing brake pipes as a temporary bung
