alistairolsen
| posted on 3/12/09 at 04:35 PM |
Brakeline parts
Hi, Im looking to order some bushes from rally design, but figured I may as well get the bits for my brakelines at the same time.
Seeing as Im 100 miles away from the bits, can someone tell m which ends I need to go onto Wilwood Powerlites? Also, Im using Mazda MX5 rear
calipers, does anyone know offhand, or know of source where I might find the correct fitting for these?
At the inboard end i want to use this style of fitting
in a mount on the chassis and then go to copper lines. I assume the convex and concave options refer to the shape of the flare and both will take
standard nuts? Any advantage to the different flare styles?
Finally, I see the euroquip reusable fittings which re what I need, but the end fittings above are only available in what I assume are crimp on? Or am
I missing something?
Cheers!
My Build Thread
indykid
| posted on 3/12/09 at 05:44 PM |
the mx5 rear calipers use 90degree m10 banjos and m10x1 bolts
wilwoods are 1/8npt
concave/convex....i dunno
if you need any more help, drop me a u2u incase i miss the thread
tom
[Edited on 3/12/09 by indykid]
gavin174
| posted on 3/12/09 at 05:51 PM |
Personally I would speak to Russ Bost at Furore for the brakelines..
I know lots of people who are very happy with the service he provides..
www.furorecars.co.uk or u2u on here
alistairolsen
| posted on 3/12/09 at 07:48 PM |
Thanks a lot for the gen on the calipers!
Id be perfectly happy to get them from Russ, but I kind of fancy the challenge of doing them myself. Also, Im intending to change the rear calipers
once the car is on the road so thought if I made them a couple of inches overlength I could change the ends later.
My Build Thread
mad-butcher
| posted on 4/12/09 at 09:45 AM |
sva were never happy with self assembly/reusable braided hoses and yes you can tell the difference
tony
alistairolsen
| posted on 4/12/09 at 10:02 AM |
oh I didnt realise, I assumed they were ok.
Might ask russ if he can do them and I can return them at a later date for new ends.
My Build Thread
