Author: Subject: Wheel cylinders part 2
prawnabie
posted on 19/1/10 at 09:10 PM Reply With Quote
Hi
I am using a transit master cylinder with a 23.81mm bore. Cortina calipers up front with standard MK2 drums (8". CEC car so weighs a fair bit.
What wheel cylinder sizes should I be using on the rear? I currently have 22.6 but I am redoing the rear brakes so wondering If i should get these or the 19/17mm ones.
Shaun
woolly
posted on 19/1/10 at 09:27 PM Reply With Quote
are the rear brakes too powerful at the moment.
woolly
prawnabie
posted on 19/1/10 at 09:38 PM Reply With Quote
Not that i have noticed, but tbh I don't drive it that hard
woolly
posted on 19/1/10 at 09:42 PM Reply With Quote
reducing the rear wheel cylinder size will reduce the braking effort and give you slightly less pedel movement.
sorry if you know that.
woolly
prawnabie
posted on 19/1/10 at 09:43 PM Reply With Quote
I don't tbh lol
Im just looking at wheel cylinder books now to order and all the mk2's are either 17 or 19 mm bore.
woolly
posted on 19/1/10 at 10:00 PM Reply With Quote
mk2 escorts and cortina 3s used the girling 8 and 9 inch rear drums.
i think one of the cortina estates had the big cylinder.
really testing my memory now.
woolly
marcjagman
posted on 19/1/10 at 10:04 PM Reply With Quote
Can't you just drill holes in the brake shoes?
britishtrident
posted on 20/1/10 at 07:55 AM Reply With Quote
Worry more about the master cylinder bore --- way too big
prawnabie
posted on 20/1/10 at 10:21 AM Reply With Quote
Sorry master cylinder bore is 22.2mm
britishtrident
posted on 20/1/10 at 11:44 AM Reply With Quote
7/8" is way too big for use without a servo.
[/I]
MikeR
posted on 20/1/10 at 12:44 PM Reply With Quote
look up the posts by dick axtell - i think it was he who did some maths on the subject when he worked for girling.
it will be 4 or 5 years ago at a guess (maybe more)
whitestu
posted on 20/1/10 at 01:32 PM Reply With Quote
I changed from a 22 to 19mm MC and is does make a worthwile improvement. Not that the brakes were in any way bad with the 22mm, just felt very sloid and a bit woody!
the 19mm gives more pedal travel, but more power and progression.
britishtrident
posted on 20/1/10 at 01:51 PM Reply With Quote
Back to wheel cyilinders -- based on experience with Imp rear brakes which were 8" inch drums almost identical to the MK1 Escort. increasing the wheel cylinder bore runs into the law of dimishing returns. A difference could be felt swapping from 0.75" bore to 0.7" bore rear cylinders but changing up from 0.75" to 7/8" bore cylinders made no difference.
With drum brakes the distortion of the mechanical bits ie shoes and drums starts to have a bigger effect when you try to put too much force into them.
[/I]
prawnabie
posted on 20/1/10 at 05:20 PM Reply With Quote
Ok thanks for the replies. I will try a set of 17.8mm cylinders and see how it goes!
