F1 Mini
posted on 29/4/04 at 06:43 PM |
ANTI Roll Bars has anyone fitted them to there Locosts ?
I know wieght will be a factor as My car has a Mini Shell strapped to it and the target wieght will be 580 Kgs, what is the average wieght of a Locost
? and what kind a roll bars have been fitted ?
Clive
[Edited on 30/4/04 by F1 Mini]
F1 Mini
posted on 30/4/04 at 08:09 AM |
I think I may have worded this wrong. What I meant was Anti roll bars, for the suspension. Not roll over bars, sorry for the confusion there.
Any pic's of them etc.
pbura
posted on 30/4/04 at 10:20 AM |
Clive,
Here's a thread with some pics:
http://www.locostbuilders.co.uk/viewthread.php?tid=6859
The norm is to have one only in the front, but I'm thinking that with IRS (lower roll center), one in the back might be helpful as well.
Pete
Pete
NS Dev
posted on 30/4/04 at 10:42 AM |
I am going to try mine and if it needs a bar on the front or back then it will get one. Did this with my grasser, hence why the bar on the back never
got painted properly!! Doh! (see photo archive and all will be clear!!)
[Edited on 30/4/04 by NS Dev]
zetec
posted on 1/5/04 at 02:48 AM |
Fitted ARB on my MK. See some pics on archive.
pbura
posted on 1/5/04 at 06:07 AM |
Very nice, zetec!
Did you get it from MK?
Pete
F1 Mini
posted on 1/5/04 at 09:16 AM |
What's the material thickness etc and how long are the arm's ?
Also did you drive it with and without it connected ?
NS Dev
posted on 1/5/04 at 11:16 AM |
A nice use of those Stauff hydraulic pipe clamps there Zetec, they are very handy (and nice and cheap!) for that job aren't they!!
zetec
posted on 3/5/04 at 09:24 AM |
Yep got it from MK. Martin has started fitting on some turnkey cars. I think it is 19mm tube. Wouldn't be tricky to make if you can get the
right tube and bend it. For what they were asking I thought not worth me making taking into account the mounts and rod ends. I think it makes a
difference and suspect they back will get one next. See caterham and Westfield fit them, love or hate them they normally research these things.
Mark Allanson
posted on 3/5/04 at 06:48 PM |
I think it is 19mm tube. Wouldn't be tricky to make if you can get the right tube and bend it.
If you got the right tube, you could NOT bend it - thats the idea of the ARB, it springs back! If you use heat to bend it, you then have to reheat
treat it to get back the springing action.
I would have thought that a torsion bar from something small would do the job, they normally have splined ends, and you could cut the female spline
part from the car being robbed, and make a lever arm (2!) to attach to the lower wishbone.
I think I'll start looking under cars at work for a suitable source - Pug 106 comes to mind
NS Dev
posted on 3/5/04 at 08:29 PM |
In theory I agree Mark, but in practice you will find different.
Having had no advice and nothing to lose I made the rear anti roll bar on my grasser (see my photo archive though forgive the state of it, it had been
raced for a year!!) from cold drawn 19mm OD 3mm Wall mild steel tube. I heated it and bent it bit by bit in a vice and it is fine.
It works great, have run with it connected and disconnected and with trailing arm rear suspension (no built-in anti-roll) it is very noticeable in
effect!
The steel does not twist far enough to reach it's yield point (even though this is quite low) and so does not get permanently twisted, and that
is with 10 inches of suspension travel!!!!
Mark Allanson
posted on 3/5/04 at 09:02 PM |
I think in higher mileage applications, the mild steel would fatigue fracture after a while, but I suppose you could just replace it as it is cheap
and easy to make
NS Dev
posted on 3/5/04 at 09:13 PM |
Again, as long as it is not welded it seems to be ok (well to fairly high mileage anyway) I know of a very high profile kit car that uses mild steel
anti roll bars, and the kits that you can buy from Rally Design etc use mild steel.
F1 Mini
posted on 3/5/04 at 09:26 PM |
I always woundered what material is used, but have never found out exactly what grade of steel. I have seen a straight tube with flat bar welded at
either end at 90 degrees, on a few race cars so welding can't be that bad.
[Edited on 3/5/04 by F1 Mini]
NS Dev
posted on 3/5/04 at 09:39 PM |
I did 3 laps of donington in an extremely reputable (and expensive) kit car with an experimental welded blade-adjustable anti-roll bar and it snapped
on the heat affected zone right in the middle of Redgate......I made sure I didn't weld mine!!!!!!!
F1 Mini
posted on 4/5/04 at 06:21 PM |
Oops, I bet that was fun...
NS Dev
posted on 4/5/04 at 07:01 PM |
Hmmmm, well I didn't crash but to put it technically (which wasn't how I put it at the time!!) the car did change attitude mid-corner
quite dramatically!
NS Dev
posted on 4/5/04 at 07:05 PM |
Just another thought though, it was tube welded on at about 110 degrees in this case and it was the adjuster tube (the "blade" tube) that
broke, not the main torsion tube, and it broke in bending at the weld, not torsion, so maybe not quite as clear cut as I made out!
NS Dev
posted on 4/5/04 at 07:11 PM |
Gosh I am posting lots here!! Just to go back to Mark Allanson's point about the mild steel fatigue failing, this is possible, but it is also
possible with high grade alloy steel as well. It is just the stress level that the fatigue occurs at that is different.
I cannot remember the exact details, but the "cycles to failure" vs "stress applied" graph is an exponential curve, so up to a
certain applied stress, the cycles to failure is infinite. As long as the anti-roll assembly is working within this stress range for the material used
(including welds and their "de-rating" factors) then there will be no problem whatever material used.
crbrlfrost
posted on 4/5/04 at 07:27 PM |
I agree with NS Dev. As long as the fatigue limit isn't exceeded, you should be golden. As far as welding goes, if you want to splurge a few
bucks on having the whole assembly (bars and arms if welded on) annealed (ie stress relieved) than you can probably even get by with a fabrication
(good welds, no major pin holes or porosity). Thats a lot of qualifiers, but adds an option.
