Author: Subject: Rubber U/J that fits to steering rack
L5W
posted on 20/3/10 at 12:14 AM Reply With Quote
Hi,
I'm going to need to modify my steering column link in order to clear the oil filter on my early Zetec E.
While I'm in the process, is it worth changing the sierra's rubber U/J fitting that fits over the rack's spigot for a solid metal U/J?
I'm thinking rubber might perish and fail over time. Or is this particular U/J made of rubber for a reason?
Lee
big_wasa
posted on 20/3/10 at 12:17 AM Reply With Quote
I would put a proper uj in.
L5W
posted on 20/3/10 at 12:22 AM Reply With Quote
wow, that was a quick response!
need to do some shopping now.....
thanks
Lee
big_wasa
posted on 20/3/10 at 12:25 AM Reply With Quote
reason being, to get the miss-alignment when you move the shaft over.
MikeRJ
posted on 20/3/10 at 12:06 PM Reply With Quote
It's simply to isolate the steering wheel from vibration and noise generated by the tyres/road surface. Most modern tin tops will have something similar, but it's not something you will find on older cars and competition cars...i.e. ones that have plenty of steering feedback!
The UJs are out of phase!
[Edited on 20/3/10 by MikeRJ]
austin man
posted on 20/3/10 at 12:48 PM Reply With Quote
Ive been running mine with the rubber joint as has the brother in law with no probs I think I have some pics in my archive showing the modification when using the silvertop zetec. I would advise that you fit the alternator as well before doing the mod as the shaft / UJ can foul the alternator if done worngly
MikeRJ
posted on 20/3/10 at 01:02 PM Reply With Quote
It won't give any problems if the rubber is in good condition, it just provides a degree of isolation that may not be desirable in a sports car. Then again if you are doing a lot of touring it may make driving it a bit less fatiguing.
posted on 20/3/10 at 01:18 PM Reply With Quote
Each to their own, I don't think I'd fancy having my steering connected by a bit of perishable rubber..... Steering is kind of useful, especially at high speed....
MikeRJ
posted on 20/3/10 at 01:48 PM Reply With Quote
I can almost guarantee your tin top (if it's reasonably modern) has a chunk of rubber isolating the column from the rack!
posted on 20/3/10 at 02:55 PM Reply With Quote
The rubber joint is an isolator and must be used straight. Any angle and it will flex against the rivits and fail.
Solid uj's with a sliding joint is what you need.
L5W
posted on 20/3/10 at 08:35 PM Reply With Quote
Thanks all, as advised, I'll fit the alternator first and then see how much room there is to carry out the modification to the steering. Based on the replies, I'll get a new steel U/J to replace the rubber one from my donor.
cheers,
Lee
