Author: Subject: Bad day at the office
Xtreme Kermit
posted on 28/3/10 at 07:34 PM Reply With Quote
So in the process of fitting my new driveshafts, I have managed to use the wrong torque setting and snap some of the Lobro joint bolts. (I know - numpty!)
Question - anyone know anywhere in herts where I can get hold of a few M8x50 cap head high tensile screws tomorrow?
iank
posted on 28/3/10 at 07:50 PM Reply With Quote
In an emergency cromwell do packs of 100 for £17.81 if you have one nearby.
http://www.cromwell.co.uk/QFT6001015W
Not cheap, a specialist fastener place should be able to sort you out for less.
Anonymous
Xtreme Kermit
posted on 28/3/10 at 07:56 PM Reply With Quote
Looks doable - one in Bedford and one in Luton!
Thanks for the lead!
PAULD
posted on 28/3/10 at 07:59 PM Reply With Quote
Anglia fasteners, Bedford. No minimum order and cash accepted.
Davegtst
posted on 28/3/10 at 08:02 PM Reply With Quote
Asset tools in Hitchin do loads of different bolts and fixings. They are on wilbury way i think.
Xtreme Kermit
posted on 28/3/10 at 08:07 PM Reply With Quote
Brill!!!! Getting closer all the time
MakeEverything
posted on 28/3/10 at 08:32 PM Reply With Quote
you need to buy 100, ill buy some off you!!
Kindest Regards,
Richard.
Xtreme Kermit
posted on 28/3/10 at 08:42 PM Reply With Quote
No problems Richard!
MakeEverything
posted on 28/3/10 at 08:47 PM Reply With Quote
Thanks! I snapped one (dont ask) but i found the set that came with the CV joint that i fitted. Still, id rather replace them all if i can.
What IS the correct torque setting btw?
Kindest Regards,
Richard.
Xtreme Kermit
posted on 28/3/10 at 09:21 PM Reply With Quote
turns out it is 25 lb ft (34 Nm)
Somewhat lower than I set my wrench to (don't ask)
55ant
posted on 29/3/10 at 07:32 AM Reply With Quote
ill have to double check but im pretty sure i have 6 lying around doing not a lot, there all yours if you want them, ill be in royston this evening.
ill double check though, may be m10,
iank
posted on 29/3/10 at 07:50 AM Reply With Quote
250 lb ft? takes quite a bit to shear off a 12.9 M8
[Edited on 29/3/10 by iank]
Anonymous
Grimsdale
posted on 29/3/10 at 08:13 AM Reply With Quote
i've got a spare set if anyone wants. Send me a u2u
blakep82
posted on 29/3/10 at 08:59 AM Reply With Quote
i have to ask now
what did you set it to?!
________________________
55ant
posted on 29/3/10 at 09:24 AM Reply With Quote
just had a look and they are m10, sorry mate,
Xtreme Kermit
posted on 29/3/10 at 09:47 AM Reply With Quote
i have to ask now
Based on recent experience - I would not recommend a setting of much over 54Nm and definitely not using 70Nm
mcerd1
posted on 29/3/10 at 10:24 AM Reply With Quote
..one other thing to ask you - are you using any thread lock / the ford twin washer things ?
only asking as a few people have had them come loose
Xtreme Kermit
posted on 29/3/10 at 11:50 AM Reply With Quote
most definitely.
I am using to ford locking washers (semi circle - takes two bolts) and a thread lock fluid too.
This will not stop me checking them regularly though as I do not fancy the aftermath of them coming loose either...
Xtreme Kermit
posted on 29/3/10 at 06:42 PM Reply With Quote
No probs - thanks for checking!
Off to Bedford for a box of 100 tomorrow first thing!
