Author: Subject: Tyre change 195/45/15 to 195/55/15 - is it worth it?
Steve Lovelock
posted on 30/5/10 at 08:13 AM Reply With Quote
I have a Luego with 195/45/15 rear tyres and the gearing is to low, ie I end up doing 3000 rpm in top at 70 and I would like to be doing much less. If I change to 195/55/ 15 would it make much difference?
ReMan
posted on 30/5/10 at 08:21 AM Reply With Quote
http://www.tyresave.co.uk/tyresize.html
7% difference of 3000, so not a lot really
[Edited on 30/5/10 by ReMan]
matt_claydon
posted on 30/5/10 at 08:22 AM Reply With Quote
7.2% difference in rolling circumference will give you 2780 rpm at 70 with the bigger tyres.
Edit: Too slow
[Edited on 30/5/10 by matt_claydon]
ashg
posted on 30/5/10 at 08:25 AM Reply With Quote
its a 7% difference
at 70 you will be doing 74.9mph
2790rpm down from 3000rpm
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
RazMan
posted on 30/5/10 at 08:39 AM Reply With Quote
I just changed my rears from 245/35/17 to 245/40/17 and although the difference is only small, it made quite a difference to my revs - 1st gear becomes a useable gear and 5th is now almost an overdrive.
Raz
mcerd1
posted on 30/5/10 at 09:34 AM Reply With Quote
7% might not be much, but its as much as changing the diff ratio by one step
eg. 3.62 -> 3.38 = +7%
MikeRJ
posted on 30/5/10 at 09:36 AM Reply With Quote
Much higher gearing is going to put a dent in performance. 23.3mph/1000 RPM in a 7 seems like pretty tall gearing already?
omega 24 v6
posted on 30/5/10 at 10:14 AM Reply With Quote
Also be aware that if your front wings are close to the tyres now then they may be touching when you go up a profile. DON'T ASK
MikeRJ
posted on 30/5/10 at 10:18 AM Reply With Quote
Also note that 195/55R15 is a significantly more expensive tyre size than 195/50R15.
[Edited on 30/5/10 by MikeRJ]
