smart51
| posted on 15/6/10 at 10:11 AM |
master cylinder plumbing
I have a fiat master cylinder for my 3 wheeler build. It has 2 circuits each with 2 ports. Can I just block one up for the "missing"
rear wheel?
Also, do they deliver the same pressure per circuit or per port? I don't want to double the brake effort at the rear wheel by only having one
of them.
blakep82
| posted on 15/6/10 at 10:17 AM |
i would think about connecting them both up with a T piece, and the output from the T goes to the brake.
oh yeah, that might double the pressure though...
[Edited on 15/6/10 by blakep82]
________________________
turbodisplay
| posted on 15/6/10 at 10:45 AM |
Pressure will not double, the only difference will be less pedal movement, about 10 - 30% less, as the fluid circuit will be a bit less.
Darren
NS Dev
| posted on 15/6/10 at 03:13 PM |
I've never used a fiat cylinder, but I would "assume" that they are similar to everybody elses, in which case yep it will be fine
with 1 port per circuit blanked off, I have done this many times with peugeot 205/106 cylinders which are great little items for special builds with
no servo!
