Author: Subject: A suspension measurement favour!
nitram38
posted on 21/6/10 at 12:38 PM Reply With Quote
Some of you know about my hydraulic ram project for raising the rideheight of the MotaLeira.
My car has inboard shocks on cams.
Im interested in how much a 7 will rise up at the front if the front shock is extended by 33mm.
So I'm asking if anyone could try and check it for me?
A friend wants a kit but I'm wondering if 33mm shock extension will be enough?
MikeCapon
posted on 21/6/10 at 02:52 PM Reply With Quote
Hi. The only precise measure I have is off a McSorley and the front ratio was 1.8:1 so your 33mm on the shock works out to a bit over 18mm at the wheel.
Hope this helps,
Mike
ETA Oh dear, oh dear. It couldn't have been the drink so I can only put this one down to old age. Correction added in new post.
I need a Terry F*ckwit smiley here.
[Edited on 22/6/10 by MikeCapon]
40inches
posted on 21/6/10 at 08:42 PM Reply With Quote
Hope this helps,
Mike
Is that correct? Checked my MK front and 3.5inches of shock travel gives 6inches of wheel travel
JF
posted on 21/6/10 at 11:04 PM Reply With Quote
Yeah the other way around seems more logical to me aswell. 33mm shock extension being about 60mm at the wheel. If it is indeed 1:1.8
nitram38
posted on 22/6/10 at 01:49 AM Reply With Quote
Just thinking aloud, the ratio is governed from the point the shock meets the wishbone and the distance from the shock mount to the upright centre line. In theory the upright centre line must move through a longer distance than the shock arc. So ride height change must be greater than shock travel.
[Edited on 22/6/2010 by nitram38]
Staple balls
posted on 22/6/10 at 01:56 AM Reply With Quote
What you need is some cardboard and some of these.
nitram38
posted on 22/6/10 at 02:07 AM Reply With Quote
Yes I know!
I did have solidworks on my PC and I used to use it.
It would be good if I could get the car actual measurement though, otherwise I will have to get longer rams made.
MikeCapon
posted on 22/6/10 at 08:57 AM Reply With Quote
Blimey!! Sorry guys.... Bit of a blonde moment there.
You are all right and I am wrong. 33 X 1.8 = 59.4
Shame I'm too old to go back to school
Mike
