PuppiesBalls
| posted on 29/6/10 at 10:01 AM |
SIERRA 7.5" rear diff!...... Going to need a new rear cover plate!
Well basicly I was advised that I could cut the lug off the back of the diff however it seems I cut abit too deep
Does anybody know where I could get a replacement back plate and new gasket cheap
Also what spec of oil would you recommend putting back in there (& how much does it take)
Thanks in advance gents
| posted on 29/6/10 at 10:47 AM |
So, you've cut through into the casting void...
Nobody with a tig that can weld a plate over it?
1 litre of transmission fluid should do it. It will say on the bottle what it is specified for. I got mine in Halfords.
LG,
Gary 7
| posted on 29/6/10 at 10:49 AM |
The diff backplate is fitted without a gasket from new ,i use a smear of instant gasket when refiting. The oil capacity is 1.3 litres of gear oil 90
EP for the 7.5 . Sorry cant help with the backplate.
| posted on 29/6/10 at 02:06 PM |
I can confirm it's more than the 750ml of oil I've been running my diff on for the last eight years
