Author: Subject: Bra Trike toe in or toe out?
mangogrooveworkshop
posted on 30/7/10 at 02:16 PM Reply With Quote
Mate has got a 2cv based bra triking style kit car.
he has just got hold of some new track rodends and needs to do the tracking.
as these are the drivin and steering wheels he was told toe out...
toe out makes any thing nervous and unpredictable.
what is the general concensos of the way the tracking should be set?
thanks in advance
dinosaurjuice
posted on 30/7/10 at 02:25 PM Reply With Quote
every FWD car i know of has slight toe-out. probably a good place to start.
loggyboy
posted on 30/7/10 at 02:26 PM Reply With Quote
Toe on FWD is generally considered to be best set between neutral and 1 degree of toe out as when power is supplied to the wheels they pull themselves 'in' making them closer to dead straight.
[Edited on 30/7/10 by loggyboy]
smart51
posted on 30/7/10 at 02:29 PM Reply With Quote
With FWD the front wheels pull the car along. Compression of the suspension bushes will turn static toe out into parallel wheels. I can't see how a single rear wheel would affect it so the general advice would be a good starting point. If he doesn't like it, he could try reducing it a bit and see if it improves.
britishtrident
posted on 30/7/10 at 03:20 PM Reply With Quote
A lot of older fwd cars use toe-out
[/I]
blue2cv
posted on 30/7/10 at 08:37 PM Reply With Quote
What tyres is he using, if its those bloody awful crossply things that make it 'look right' it will be nervous, last one of those we had in on crossplies when you drove it was a lottery which kerb you were going to hit
mangogrooveworkshop
posted on 30/7/10 at 09:09 PM Reply With Quote
I will ask what tyres he has
